Cube4.12 SDIO generating code bug? 4bit settings generates 1B
Question asked by van_schelven.rob on Dec 14, 2015
Latest reply on Dec 15, 2015 by van_schelven.rob
If have a disco429 board modified, removing hardware that i dont use for an experiment and in order to connect and access an SD memory card by 4 bit.
The settings in CubeMX is set to SD 4 bits wide bus, but the code generated is "hsd.Init.BusWide = SDIO_BUS_WIDE_1B;"
Is this because i started the cubemx project with the selection of the disco board or might it be considered a bug?
Thanks!
