eeprom 24c02 on stm32f0
Question asked by serao.pietro on Apr 17, 2013
Latest reply on Apr 17, 2013 by Clive One
Hi guys, i'm tryng to read and write some bytes on an EEprom 24c02 via i2c bus using an stm32f0discovery device.
I've found an example using some libraries like "stm320518_eval_i2c_ee.h" etc.
I've solved some importing problem simply coping code in the original main.c file.
Now the program compiles without warnings but it remain in the sEE_WriteBuffer(...) function.
Connecting a scope on PB6 and PB7 pins i can't see nothing.
Finally my hardware configuration is the seguent:
EEPROM pins 1,2,3,4 (E0,E1,E2,VSS) to micro's GND
EEPROM pin 8 (Vcc) to micro's 3V pin
EEPROM pin 7 (WC) to micro's 3V using an 1Kohm resistor
EEPROM pin 6 (SCL) to micro's PB6
EEPROM pin 5 (SDA) to micro's PB7
finally in stm320518_eval_i2c_ee.h file i've changed the seguent define:
#if defined (sEE_M24C08)
 #define sEE_PAGESIZE           8
And this is my main code:
#include "stm32f0xx.h"
#include "stm320518_eval.h"
#include "stm320518_eval_i2c_ee.h"
 #include "stm32f0xx_i2c.h"
/** @addtogroup STM32F0xx_StdPeriph_Examples
/** @addtogroup I2C_EEPROM
typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
/* Uncomment the following line to enable using LCD screen for messages display */
//#define ENABLE_LCD_MSG_DISPLAY
#define sEE_WRITE_ADDRESS1        0x50
#define sEE_READ_ADDRESS1         0x50
#define BUFFER_SIZE1             (countof(Tx1Buffer)-1)
#define BUFFER_SIZE2             (countof(Tx2Buffer)-1)
#define sEE_WRITE_ADDRESS2       (sEE_WRITE_ADDRESS1 + BUFFER_SIZE1)
#define sEE_READ_ADDRESS2        (sEE_READ_ADDRESS1 + BUFFER_SIZE1)
#define countof(a) (sizeof(a) / sizeof(*(a)))
uint8_t Tx1Buffer[] = "/* STM32F0xx I2C Firmware Library EEPROM driver example: \
                        This firmware provides a basic example of how to use the I2C firmware library and\
                        an associate I2C EEPROM driver to communicate with an I2C EEPROM device \
                        I2C peripheral is configured in Master transmitter during write operation and in\
                        Master receiver during read operation from I2C EEPROM.*/";
uint8_t Tx2Buffer[] = "/* STM32F0xx I2C Firmware Library EEPROM driver example : \
                        I2C1 interfacing with M24LR64 EEPROM */";
uint8_t Rx1Buffer[BUFFER_SIZE1], Rx2Buffer[BUFFER_SIZE2];
volatile TestStatus TransferStatus1 = FAILED, TransferStatus2 = FAILED;
volatile uint16_t NumDataRead = 0;
void sEE_LowLevel_DeInit(void);
void sEE_LowLevel_Init(void);
TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f0xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f0xx.c file
  /* Initialize the I2C EEPROM driver ----------------------------------------*/
  sEE_Init();
  /* First write in the memory followed by a read of the written data --------*/
  /* Write on I2C EEPROM from sEE_WRITE_ADDRESS1 */
  sEE_WriteBuffer(Tx1Buffer, sEE_WRITE_ADDRESS1, BUFFER_SIZE1);
  /* Wait for EEPROM standby state */
  sEE_WaitEepromStandbyState();
  /* Set the Number of data to be read */
  NumDataRead = BUFFER_SIZE1;
  /* Read from I2C EEPROM from sEE_READ_ADDRESS1 */
  sEE_ReadBuffer(Rx1Buffer, sEE_READ_ADDRESS1, (uint16_t *)(&NumDataRead));
  /* Check if the data written to the memory is read correctly */
  TransferStatus1 = Buffercmp(Tx1Buffer, Rx1Buffer, BUFFER_SIZE1);
  /* TransferStatus1 = PASSED, if the transmitted and received data
     to/from the EEPROM are the same */
  /* TransferStatus1 = FAILED, if the transmitted and received data
     to/from the EEPROM are different */
  /* Second write in the memory followed by a read of the written data -------*/
  /* Write on I2C EEPROM from sEE_WRITE_ADDRESS2 */
  sEE_WriteBuffer(Tx2Buffer, sEE_WRITE_ADDRESS2, BUFFER_SIZE2);
  NumDataRead = BUFFER_SIZE2;
  /* Read from I2C EEPROM from sEE_READ_ADDRESS2 */
  sEE_ReadBuffer(Rx2Buffer, sEE_READ_ADDRESS2, (uint16_t *)(&NumDataRead));
  TransferStatus2 = Buffercmp(Tx2Buffer, Rx2Buffer, BUFFER_SIZE2);
  /* TransferStatus2 = PASSED, if the transmitted and received data
  /* TransferStatus2 = FAILED, if the transmitted and received data
  /* Free all used resources */
  sEE_DeInit();
  while (1)
  * @brief  Initializes peripherals used by the I2C EEPROM driver.
  * @param  None
  * @retval None
  GPIO_InitTypeDef  GPIO_InitStructure;
  /* Configure the I2C clock source. The clock is derived from the HSI */
  RCC_I2CCLKConfig(RCC_I2C1CLK_HSI);
  /*!< sEE_I2C_SCL_GPIO_CLK and sEE_I2C_SDA_GPIO_CLK Periph clock enable */
  RCC_AHBPeriphClockCmd(sEE_I2C_SCL_GPIO_CLK | sEE_I2C_SDA_GPIO_CLK, ENABLE);
  /*!< sEE_I2C Periph clock enable */
  RCC_APB1PeriphClockCmd(sEE_I2C_CLK, ENABLE);
  /* Connect PXx to I2C_SCL*/
  GPIO_PinAFConfig(sEE_I2C_SCL_GPIO_PORT, sEE_I2C_SCL_SOURCE, sEE_I2C_SCL_AF);
  /* Connect PXx to I2C_SDA*/
  GPIO_PinAFConfig(sEE_I2C_SDA_GPIO_PORT, sEE_I2C_SDA_SOURCE, sEE_I2C_SDA_AF);
  /*!< GPIO configuration */
  /*!< Configure sEE_I2C pins: SCL */
  GPIO_InitStructure.GPIO_Pin = sEE_I2C_SCL_PIN;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
  GPIO_Init(sEE_I2C_SCL_GPIO_PORT, &GPIO_InitStructure);
  /*!< Configure sEE_I2C pins: SDA */
  GPIO_InitStructure.GPIO_Pin = sEE_I2C_SDA_PIN;
  GPIO_Init(sEE_I2C_SDA_GPIO_PORT, &GPIO_InitStructure);
  /* sEE_I2C Peripheral Disable */
  I2C_Cmd(sEE_I2C, DISABLE);
  /* sEE_I2C DeInit */
  I2C_DeInit(sEE_I2C);
  /*!< sEE_I2C Periph clock disable */
  RCC_APB1PeriphClockCmd(sEE_I2C_CLK, DISABLE);
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
#ifndef USE_DEFAULT_TIMEOUT_CALLBACK
  * @brief  Example of timeout situation management.
  * @param  None.
  * @retval None.
uint32_t sEE_TIMEOUT_UserCallback(void)
  /* Use application may try to recover the communication by resetting I2C
    peripheral (calling the function I2C_SoftwareResetCmd()) then re-start
    the transmission/reception from a previously stored recover point.
    For simplicity reasons, this example only shows a basic way for errors
    managements which consists of stopping all the process and requiring system
    reset. */
  /* Block communication and all processes */
  while (1)
#endif /* USE_DEFAULT_TIMEOUT_CALLBACK */
  * @brief  Compares two buffers.
  * @param  pBuffer1, pBuffer2: buffers to be compared.
  * @param  BufferLength: buffer's length
  * @retval PASSED: pBuffer1 identical to pBuffer2
  *         FAILED: pBuffer1 differs from pBuffer2
  while(BufferLength--)
    if(*pBuffer1 != *pBuffer2)
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
