Is Systick the way to generate a delay function
Question asked by CS on Apr 12, 2013
Latest reply on Apr 16, 2013 by CS
Hi Folks (and Clive)
I have generated timing delays using systick and I want some comments on whether it was the right way to go:-
static __IO uint32_t TimingDelay;
void Delay(__IO uint32_t nTime)
    TimingDelay = nTime;
    while (TimingDelay != 0)
void TimingDelay_Decrement(void)
    if (TimingDelay != 0x00)
     TimingDelay--;
extern "C" void SysTick_Handler(void)
    TimingDelay_Decrement();
I believe that systick is a low priority - so can this code get stuck if there is a pending higher priority interrupt??
CS
