STemWin libraries
Question asked by lowit.alan on Oct 16, 2015
Latest reply on Oct 21, 2015 by 68516
I've found that on the ST32F429 DISCO that the library STemWin STemWin522_CM4_OS_GCC.a works and yet the later version STemWin528_CM4_OS_GCC.a does not. Its hangs somewhere after GUI_X_Config(). I have the CRC module enabled.
Also the size difference in these libs, the newer ones is nearly four times the size!
Does anyone know what may have changed between versions 522 and 528?
Thank you.
