ST-Link requires admin rights...?
georg23
Posted on March 03, 2010 at 09:11
hi all,
apparently the ST-Link requires admin rights to allow program/debug. Specifically I observed that I can only program the STM8 ''Discovery Kit'' from my admin account, not the one with restricted access. Is this intended?
PS: I run Windows XP SP3 with STCD v4.1.4
Thanks in advance,
Georg
4 REPLIES 4
martinglunz9
Posted on March 04, 2010 at 10:33
Hi
I've got the same issue.
There's a convenient workaround possible (at least for me):
edit the desktop shortcut to the toos to use runas /savecred
Just add ''runas /savecred /user:admin_accout to the Target, e.g.:
C:\WINDOWS\system32\runas.exe /savecred /user:admin_account C:\Programme\STMicroelectronics\st_toolset\stvp\stvp.exe
thomasblender9
Posted on March 06, 2010 at 19:33
I had the same problem. I solved it in Windows 7 by edit the properties of C:\Program Files\STMicroelectronics\st_toolset\stvd\stvdebug.exe.
Change to tap compatibility and enable run as admin.
georg23
Posted on March 16, 2010 at 00:29
hi,
sorry for the late reply, I was on a business trip and had forgotten my discovery board...
I will need to check your tipp at work, where I have the problems. However, I suspect that the (very) restricted access rights on my office PC prohibit the use of ''runas''. I'll report tomorrow...
Georg
georg23
Posted on March 17, 2010 at 07:50
hi again,
as expected, the access restrictions prevent using ''runas'' on my office PC. My workaround is using an external RLink instead of the built-in ST-Link. At home I use the ST-Link. Not a nice solution but it works for me. Anyway, thanks a lot for your feedback!
Regards, Georg
