2023-05-29 3:35 AM
Hi everybody, i've developed an external loader for a STM32H7A3IIK6 MCU to write and read, using STMCubeProgrammer, an ISSI QSPI External Flash [IS25LP128F]. The External Loader works perfectly except for the following issue : the first time i open Cube Programmer and try to access the External Flash Memory [read or write] the Init function fails [even if i do not power cycle the electronic board]. Could it be a problem related to the "ld" file [here attached]?
2023-06-06 3:00 AM
Hello @Community member ,
I recommend you to take a look to the External QSPI loader MOOC.
And, try to follow the steps descripted in this MOOC in order to develop your external loader project.
I hope this help you!
Please let me know if the problem is solved.
Kaouthar
2023-06-06 3:00 AM
Kaouthar
