2025-09-12 3:34 AM
Hello
I am in the industrialization phase of a product based on STM32G0B0RE.
In order to optimize the flashing process for my manufacturer I made a .bat file programming the product the MCU using the STM32_Programmer_CLI.exe commmand from STM32CubeProgrammer.
Since I am not using the GUI of STM32CubeProgrammer is there any folder I can delete in the root to optimize the size of the package I'll provide. The STM32CubeProgrammer size is 1,36 Go if I can reduce it to 500 or 600 mO it could be very usefull.
Best Regards
Thibaud
2025-09-16 6:58 AM
Hello @Tiboww,
You can use the STM32CubeProgrammer package bundled in STM32CubeCLT in STM32CubeCLT | Software - STMicroelectronics, after installing, you can find the package in this directory:
C:\ST\STM32CubeCLT\STM32CubeProgrammer
The package is around 130 MBytes and is CLI only.
Hope this helps,
Aziz
2025-09-16 6:58 AM
Hello @Tiboww,
Hope this helps,
Aziz
2025-09-29 3:18 AM
Hello
It is perfect thank you.
Thibaud
