2025-10-31 8:09 AM
In STM32CubeMX 6.15.0 / Win11 I generate a default CMake project for the Nucleo-G431KB board.
The generated cmake/stm32cubemx/CMakeLists.txt contains:
# STM32CubeMX generated symbols (macros)
set(MX_Defines_Syms
USE_NUCLEO_64
USE_HAL_DRIVER
STM32G431xx
$<$<CONFIG:Debug>:DEBUG>
)but the board is a Nucleo-32, not 64. As a consequence, pinout is wrong, like a wrong pin for the USER_LED is assumed.
hth
KnarfB
2025-11-03 3:00 AM
Hello @KnarfB ,
Let me thank you for bringing this issue to our attention.
An internal ticket is submitted to the development team (Ticket Number: 220991).
I will let you know as soon as the problem is solved.
Thanks.
Mahmoud
2025-10-31 8:16 AM
Hello @KnarfB ,
Let me thank you for posting.
Your request is under investigation, and I will get back to you ASAP.
Thanks.
Mahmoud
2025-11-03 3:00 AM
Hello @KnarfB ,
Thanks.
Mahmoud
