Can use cubemx to generate lwip project in stm32h743
Yi Zhou
Posted on June 30, 2018 at 15:49
Hi all:
     Now I use stm32h743zi, using cubemx to generate LwIP project, but the LwIP option is gray. Dose anyone know that how to fix this. The following picture is the picture what I confige the cubemx project. Thanks.
#stm32cubemx. #stm32h7-ethernet
Imen.D
Posted on June 30, 2018 at 21:43
Hello
yi.zhou
To active LWIP for STM32H7, you should enable the ETH IP and FREERTOS with MBEDTLS.
Also, CORTEX_M7 CPU DCache parameter must be enabled.
This warning is mentioned when you put the cursor in LWIP Pinout.
Hope this helps you.
With Regards,
Imen
Imen
3 REPLIES 3
Imen.D
Hello
yi.zhou
With Regards,
Imen
Imen
Yi Zhou
Posted on July 01, 2018 at 14:16
Hello Imen
     This is very helpful. Thanks.
brath
hi yi Zhou
im new to controller im trying to use lwip for udp communication can u guide for lwip project creation or share ur .ioc for basic lwip
