STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1570 Views
  • 0 replies
  • 2 kudos
CubeMX - Generated files vs copied files
I'm new to CubeMX and I've read over the documentation a couple of times (speed reading) but can't quite find an answer.My question is what files exactly are generated by the tool and what files are simply copied?Is it the case that all files we find...
Too many ADC interrupt calls added by CubeMX
Hi, I've got some code that uses both ADC1 and ADC3 that I've generated with STM32CubeMX. For both ADCs I want to use interrupts. With this configuration however the CubeMX auto-generated code adds 2 separate calls to the same HAL interrupt handler, ...
DBurr by Senior
  • 2316 Views
  • 6 replies
SD card interface code genereated by STM32CUbe32 (5.5.0)
i would request imen to let us know if the STM32CubeMx 5.5.0 is addressing all the issues regarding SD card interface using SDMMC ( 4 bits and DMA). Since the code generated from CubeMX 5.5.0 for nucleo-l476rg BOARD for SD card interface does not wor...
HMaje.1 by Associate III
  • 5503 Views
  • 14 replies
  • 1 kudos
