Cannot debug CM4 on STM32MP151 (eng mode)
Mario Luzeiro
Both on Windows and on Linux, latest STM32CubeIDE, I cant get debug or run using ST-Link.
If I try to use ST-Link GDB Server
Error in final launch sequence:
    Failed to execute MI command:
    target remote localhost:61234
    Error message from debugger back end:
    Remote communication error.  Target disconnected.: Connection reset by peer.
STMicroelectronics ST-LINK GDB server. Version 6.1.0
    Copyright (c) 2022, STMicroelectronics. All rights reserved.
    Starting server with the following options:
            Persistent Mode            : Disabled
            Logging Level              : 1
            Listen Port Number         : 61234
            Status Refresh Delay       : 15s
            Verbose Mode               : Disabled
            SWD Debug                  : Enabled
    ST-LINK device status: UNKNOWN
    Waiting for debugger connection...
    Debugger connected
    Failed halting target
    Shutting down...
    Exit.
If I try to "Run" (instead of Debug) I got:
    Info : accepting 'gdb' connection on tcp/3333
    Info : Halt timed out, wake up GDB.
    Error: timed out while waiting for target halted
    Error executing event gdb-attach on target STM32MP151AACx.cm4:
    Info : New GDB Connection: 2, Target STM32MP151AACx.cm4, state: reset
    Warn : GDB connection 2 on target STM32MP151AACx.cm4 not halted
    Warn : negative reply, retrying
    Warn : negative acknowledgment, but no packet pending
    Info : stlink_dap_op_connect(connect)
    Info : SWD DPIDR 0x6ba02477
    Info : Deferring arp_examine of STM32MP151AACx.cpu1
    Info : Use arp_examine command to examine it manually!
    Info : Deferring arp_examine of STM32MP151AACx.cm4
    Info : STM32MP151AACx.cm4: Cortex-M4 r0p1 processor detected
    Info : STM32MP151AACx.cm4: target has 6 breakpoints, 4 watchpoints
    Warn : target not halted
    Info : target STM32MP151AACx.cm4 was not halted when resume was requested
    Info : dropped 'gdb' connection
    shutdown command invoked
 Using Open On-Chip Debugger
Open On-Chip Debugger 0.11.0+dev-00443-gcf12591 (2022-02-09-13:30) [ST Internal]
Licensed under GNU GPL v2
For bug reports, read
	http://openocd.org/doc/doxygen/bugs.html
srst_only srst_pulls_trst srst_gates_jtag srst_open_drain connect_deassert_srst
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : STLINK V2J39S0 (API v2) VID:PID 0483:3748
Info : Target voltage: 2.908319
Info : clock speed 4000 kHz
Info : STM32MP151AACx.cm4: external reset detected
Info : STM32MP151AACx.cpu0: hardware has 6 breakpoints, 4 watchpoints
Info : gdb port disabled
Info : starting gdb server for STM32MP151AACx.cpu0 on 3334
Info : Listening on port 3334 for gdb connections
Info : starting gdb server for STM32MP151AACx.cm4 on 3333
Info : Listening on port 3333 for gdb connections
Info : New GDB Connection: 1, Target STM32MP151AACx.cm4, state: reset
Warn : GDB connection 1 on target STM32MP151AACx.cm4 not halted
O.K.
O.K.:0xE00FFFD0
Warn : target STM32MP151AACx.cm4 is not halted (add breakpoint)
Error: can't add breakpoint: target running
5 REPLIES 5
Olivier GALLIEN
Hi @Mario Luzeiro​ ,
The only working configuration on MP1 is ST-Link (OpenOCD).
Which ST-Link probe are you using?
Which version of st-link firmware and CubeiDE ?
Olivier
Olivier GALLIEN
I'm using a ST-Link from a Nucleo board. Latest firmware.
I fount that debug capabilities on Linux build was missing. I fixed it.
However, I'm still having issues. I found I cannot start a debug session if I have debug breakpoints. I can only add it after the session start. Is that a known issue?
Olivier GALLIEN
Hi @Mario Luzeiro​
you post state (eng mode) = CM4 alone... but your comment about Linux and symptom you are observing make me think you are in production mode with A7 running Linux
Could you please clarify ?
Thx
Olivier
Olivier GALLIEN
Sorry for the confusion I mixed the thread, as in fact I have issues on all cases :/
Back to Eng mode, CM4 alone.
If I start the STM32MP1 and try to debug in Eng Mode (status is idle and green), I got the problem:
If I start the STM32MP1 and debug via LinuxCore/ProductionMode (this mode works with some other issues), then if I switch to debug (without power cycle STM32MP1) to EngMode, I am able to debug step by step but (on my case) the FreeRTOS does not start.
osKernelStart returns osErrorISR.
I also have other Interrupts setup and they dont work / and no break point.
Mario Luzeiro
I still having issues debugging, new error message:
O.K.
O.K.:0xE00FFFD0
