2025-11-17 6:18 AM
Running ST Cube IDE 1.19 on Windows 11, co-pilot autocompletions seem to be causing an issue. I see the suggestion, then a dialog pops up saying the following:
An internal error occurred during: "Generating completion...".
Invalid thread access
I look at the error log as I see the following:
Failed to parse wmic output
Exception Stack Trace:
2025-11-18 3:42 AM
It's not working for me.
2025-11-18 3:44 AM
Did you reinstall WMIC ?
2025-11-18 4:33 AM
Yes. Maybe it's related to problems with Cloudflare right now.
2025-11-18 7:46 AM
Quite possibly (glad it's not just me - I was wondering!). Also, check for an update to the Github Copilot plugin. I had one come in yesterday.
2025-11-18 11:32 PM
I am also being offered to update the IDE to version 2.0.0. Is it worth doing, or is it still buggy?
2025-11-18 11:34 PM
I'd not seen that. I'm going to try on my own PC first. Did you get GHCP working?
