STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1436 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 560 Views
  • 0 replies
How reconcile the address field within a SREC file?
Hi All,The STM32CubeIDE can produce a SREC file. I am trying to decode the Address field within the file.It should be 32 bit bigendian, however, it is 24 bit of an unknown endian style.Can someone please explain the endian style used?STM32CubeIDE Ver...
PSPF by Associate II
  • 1890 Views
  • 3 replies
STM32CubeIDE breaks on macOS when upgrading from 1.3.0 to 1.3.1. The application cannot find java after upgrade. (Resolved)
The issue is an erroneous plist: /Applications/STM32CubeIDE.app/Contents/Info.plistThere are missing sections under the Eclipse key.Below is a functional Info.plist, please compare to yours and modify if need be...<?xml version="1.0" encoding="UTF-8"...
jan by Associate II
  • 764 Views
  • 0 replies
  • 1 kudos
Resolved! Custom linker won't compile
I'm trying to reserve space in RAM for emulated eeprom. I can read and write fine, however when I try to modify the linker it won't compile. The added user section/* Specify the memory areas */ MEMORY { FLASH (rx) : ORIGIN = 0x08000000, LENGT...
MBeau.1 by Associate
  • 2631 Views
  • 3 replies
