STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1441 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 565 Views
  • 0 replies
Terminal related problems
Hi,I want to use a terminal to check serial communication. I have tried to install a terminal to my CubeIDE software. I have followed this path:Help --> Install a new software --> (I have looked for a "terminal" keyword. I have tried to install TM Te...
M.umit by Associate II
  • 2751 Views
  • 3 replies
STM32CUBE IDE FreeRTOS cmsis_os.h:461:67: warning: ISO C++ forbids converting a string constant to 'char*'
When freeRTOS header cmsis_os.h is used in *.cpp file, it generates compiler warningISO C++ forbids converting a string constant to 'char*'.Proposed fix:Change line 326 of cmsis_os.h from:typedef struct os_thread_def { char                  *name;   ...
MBel.1 by Associate
  • 1256 Views
  • 0 replies
  • 2 kudos
Not able to flush the firmware in STM32F413RH custom board
Hello,I could use DISCO-F413ZH (STM32F413ZH MCU) dev board to test some of the sensors. After successfully testing with dev board, I made custom board using STM32F413RH MCU. When I connect the custom board to computer, it detects as STM32 bootloader....
VKart.1 by Associate
  • 4207 Views
