STM32 MPUs Products and hardware related
Ask questions and find answers on STM32 microprocessors, including hardware, power, DRAM, flashing, interfacing, device tree, and peripherals.
CubeMX includes different MPU
If you try to generate code for, say, STM32MP151AAA you will find inside the dts files, some includes related to another MPU (like STM32MP157C):#include "stm32mp157c.dtsi" #include "stm32mp157caa-pinctrl.dtsi" #include "stm32mp157c-security.dtsi"And ...
Mark81 by Associate III
  • 1036 Views
  • 1 replies
How to install normal debian packages on the STM32MP157C-DK2? Apt-get does not update and packages can not be found.
Used device: STM32MP157C-DK2 I am trying to install several debian packages like dirmngr and apt-transport-https, however apt-get does not provide it. Apt-get update does not show any results, because sources.list.d is empty. I tried to dial in a pa...
level sensitive IRQ on GPIO
Hello, I am using the ST32MP157c-dk2. I want to adapt the mcp2518xxfd driver the bsp. The driver uses a level sensitive irq on a gpio. Since I have not been able to configure a level sensitive irq, I tried it edge sensitive. But this configuration fa...
FHill by Associate
  • 2983 Views
  • 4 replies
spread spectrum on STM32MP1
Hi,I have to use the spread spectrum on PLL4 on STM32MP1I have set the pll4 in tfa and u-boot as followstfa     pll4:st,pll@3 {    cfg = < 1 49 11 10 1 3>; csg = < 80 80 SSCG_MODE_CENTER_SPREAD >;  };u-boot  pll4:st,pll@3 {    cfg = < 1 49 11 10 1 7>...
MArdi by Associate II
  • 2604 Views
  • 4 replies
Resolved! speaker output in STM32MP157C-EV1
HI, All.I would like use speaker output in STM32MP157C-EV1. I revised the wiki but there aren't references about how play audio with speaker output. Is it enable speaker output to this board? Is it possible enable this output to play audio?Regards!Al...
AVazquez by Associate III
  • 5034 Views
  • 4 replies
How to increase the RPMsg buffer size?
i want to increase the RPMsg buffer size as suggested in this thread:https://community.st.com/s/question/0D50X0000AnuE1XSQU/what-is-the-maximum-transmission-interprocessor-bandwidth-on-stm32mp1i already tried the following:On the M4:Changing RPMSG_BU...
rengl by Associate II
  • 2062 Views
  • 1 replies
