STM32 MPUs Embedded software and solutions
Ask questions and find answers on STM32 microprocessors and dedicated embedded software solutions, such as Yocto SDK, Qt, and OP-TEE.
Resolved! Newly added i2s device returns error at kernel startup: "[ 2.359377] st,stm32-i2s 44004000.audio-controller: no irq for node 44004000.audio-controller" [Answered]
Hello,so I am using the Yocto environment and patched the device tree:diff --git a/arch/arm/boot/dts/stm32mp157-pinctrl.dtsi b/arch/arm/boot/dts/stm32mp157-pinctrl.dtsi index dd796ec03..54ef05294 100644 --- a/arch/arm/boot/dts/stm32mp157-pinctrl.dtsi...
DHerm.1 by Associate II
  • 2625 Views
  • 3 replies
Enable charging from VBAT pin in Linux
Hello,I would like to enable battery/capacitor charging from the VBAT pin on an STM32MP1 and also change the charging resistor.That would be VBE and VBRS of PWR_CR3.What would be the proper way to enable/disable the charging together with the resisto...
CErik.1 by Associate II
  • 3115 Views
  • 5 replies
Custom distribution based on OpenSTLinux
I am currently building a dedicated image for our custom board based on STM32MP1. According to the wiki and OE mega-manual, I need to create a custom distribution to be able to customize it according to our needs.I am following the steps described he...
PGE by Associate III
  • 1945 Views
  • 1 replies
Resolved! Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,6)
Hi, I've created a SD card following this guide. The generated SD card partitions can be seen in the screenshot here below. It seems to boot correctly until the kernel prompts the following error:[ 4.200445] ---[ end Kernel panic - not syncing: VF...
RBruè.1 by Associate II
  • 2086 Views
Resolved! Error while compiling custom machine
Hi, I am trying to compile an OpenSTLinux image for a target "DK2_A7" custom machine.I've followed this guide and everything seems ok until 98% of the process when the following error occurs:ERROR: tf-a-stm32mp-2.4.r1-r0 do_compile: oe_runmake failed...
  • 2366 Views
  • 3 replies
