ST-Link in P-Nucleo-WB55 board is not working due to the SWCLK wire length.
KKIM.6
Senior II
I have one of P-Nucleo-WB55 and recently bought one more P-Nucleo-WB55 board.
We are using this board to program the STM32WB55VG6YTR microcontroller in our custom board and we have succeeded more than 20 times in programming that microcontroller using ST-LINK in P-Nucleo-WB55.
However, recently we couldn't access either our microcontroller in the custom board or the dummy microcontroller in P-Nucleo-WB55 anymore. In addition, we never succeed in using the new P-Nucleo-WB55 board.
After several trials, we found that the wire length of SWCLK was the reason.
Right now, we only can access the dummy microcontroller in P-Nucleo-WB55 using a jumper pin to connect SWCLK. If we use a normal wire (resistance < 1 ohm), we cannot access even the dummy microcontroller.
This problem is big because we have to program the microcontroller in our custom circuit board.
Does anybody have a similar problem and find a solution?
Andrew Neil
What made you conclude that it was the length of the wire, specifically?
What length are you using?
Obtain a standalone programmer?
eg,
https://www.st.com/en/development-tools/st-link-v2.html
https://www.st.com/en/development-tools/stlink-v3minie.html
etc
@KKIM.6 wrote:
dummy microcontroller in P-Neucleo-WB55
I guess this is probably  just lost in translation, but the microcontroller on the board is fully functional - it's not a "dummy".
Andrew Neil
eg,
etc
We can access the dummy microcontroller using a very short jumper pin connecter.
If we replace the jumper pin connecter to a normal 2.54 wire (length < 15 cm, resistance < 1 ohm), we cannot connect to the dummy microcontroller even.
This problem has happened recently with an old P-Neucleo-WB55 board.
The new P-Neucleo-WB55 board has had this problem from the beginning.
Such a problem wasn't last year.
Is there any update on the CubeProgrammer or any noticeable change?
Try adding more ground wires between the boards. Different Slew behaviour of different chip runs by result in excessive ground bounce
