Unresponsive Buttons on STM32F7 Disco After Holding Click
NB1
Hello everyone,
I added two buttons (the button type is shown in the attached picture) to my UI, each controlling two relays with the STM32F7 Disco. When I maintain a click on one of the buttons, both buttons turn off and become unresponsive. I need to reset the board to make them functional again.
Can anyone explain why the UI behaves this way and suggest a solution?
Thanks,
BR,
Nourhene.
3 REPLIES 3
Hello @NB1 ,
In your code, how do you handle the switching between the buttons? I think it would be way easier to just use the Toggle Button widget in the TouchGFX designer which already implements the behavior you are looking for.
Please give it a try and test if the same issue still exists
Best regards,
Mohammad MORADI
Hello @Mohammad MORADI ESFAHANIASL,
Thank you for your response. I believe we are discussing the same widget. I am also using the button you mentioned, but the code I generated is slightly different from the code provided in this link: Toggle Button.
My question is: Could this difference be the reason for the issues I'm experiencing with my buttons?
Here is my generated code:
#include <gui_generated/screen1_screen/Screen1ViewBase.hpp>
#include <touchgfx/Color.hpp>
#include <images/BitmapDatabase.hpp>
Screen1ViewBase::Screen1ViewBase()
    __background.setPosition(0, 0, 800, 480);
    __background.setColor(touchgfx::Color::getColorFromRGB(0, 0, 0));
    add(__background);
    toggleButton1.setXY(345, 215);
    toggleButton1.setBitmaps(touchgfx::Bitmap(BITMAP_ALTERNATE_THEME_IMAGES_WIDGETS_TOGGLEBUTTON_MEDIUM_ROUNDED_ON_NORMAL_ID), touchgfx::Bitmap(BITMAP_ALTERNATE_THEME_IMAGES_WIDGETS_TOGGLEBUTTON_MEDIUM_ROUNDED_OFF_LIGHT_ID));
    add(toggleButton1);
Screen1ViewBase::~Screen1ViewBase()
void Screen1ViewBase::setupScreen()
I can see that you have assigned to action to your button.
How do you control the communication between the toggle and your relays?
Mohammad MORADI
