2025-10-31 10:29 AM
Dear all,
Can you please help to point me to any of the repeat button implementation example?
I have successfully implement the single button with plus and minus but the number target is too big and it is taking too many clicks to get to the target number. I would like to use the repeat button feature to achieve the goal that if the repeat button is holding, the setting will go faster and reach the goal.
2025-11-01 12:37 AM
Try search Long press
void Screen3View::handleClickEvent(const ClickEvent& evt)
if(evt.getType()==ClickEvent::PRESSED && flexButton1.getAbsoluteRect().intersect(evt.getX(), evt.getY()))
evaluate_long_press = 1;
else if(evt.getType()==ClickEvent::RELEASED)
evaluate_long_press = 0;
Screen3ViewBase::handleClickEvent( evt);
2025-11-01 12:37 AM
