Which is better: lower prescaler (PSC) value or lower period (ARR) value?
JBond.1
Senior II
Hi, I wonder which one is better for Timer setup:
  1. lower prescaler (PSC) value and higher period (ARR) value?
  2. lower period (ARR) value and higher prescaler (PSC) value?
waclawek.jan
What is"better"?
Whichever setting suits your application is OK. Higher prescaler might theoretically lead to lower power consumption, but the difference will be probably entirely negligible.
waclawek.jan
What is"better"?
I usually prefer lower PSC in order to have better resolution, but sometimes resolution doesn't matter. Note that ARR needs to be nonzero.
Lower power consumption is better, so I will try to choose larger PSC and lower ARR if possible.
Like at 72Mhz cpu:
1ms timer PSC = 7199 ARR = 9
100ms timer PSC = 59999 ARR = 119
