2022-11-14 04:19 AM
I cannot find more info about this register on RM or PM documents for STM32H750XB.
I'm searching for register name. The register is about enabling debug features.
Am I missing something or is this register described somewhere else (maybe for all M7 platforms) ?
Thanks.
2022-11-14 04:27 AM
The DEMCR is a register of the ARM core Cortex-M7 and stands for "Debug Exception and Monitor Control Register". You will find some explanation in the ARM documentation, e.g. here.
Does it answer your question?
/Peter
2022-11-14 04:27 AM
/Peter
2022-11-14 05:02 AM
Is there a page where one could find (base) addresses for all system registers ?
I'm constantly seeking for that information (offsets are mentioned, but base addresses are hard to find)...
Thanks.
2022-11-14 05:16 AM
The base addresses can typically be found in the Reference Manual, section
Memory and Bus Architecture > Memory Map and Register Boundary Addresses. For the STM32H750, this can be found starting at section 2.3.2.
Good luck!
/Peter
2022-11-14 05:19 AM
Thanks for help,,,
