Voltage control Loop frequency
Milan1367
Hi
I am using X-CUBE-DPOWER to set the parameters for my Buck converter operating conditions on a B-G474E-DPOW1 evaluation board.
I am trying to understand how the controller is implemented. For the PWM switching frequency, I know that this is done by configuring HRTIMER.  However, I am unsure how this is implemented for the Voltage/Current control loop frequency. E.g.  If I change the value to half, which part of the MCU or code will be changed to apply this setting?
Thank you.
0 REPLIES 0
