2023-07-03 12:33 AM
I just want to know about using SPI CS alternate function or a simple GPIO output.
In my design I just have a pin with no SPI CS alternate function available, so could I use it as a simple GPIO output?
2023-07-03 1:35 AM
Hi @JuanjoAlm ,
by SPI CS you mean "chip select" or in other words "slave select"?
We call it NSS (negative slave select) and you can replace it with a GPIO without problem. Reference manual even describe some scenarios where it's actually recommended, like multi-master application.
BR,
J
2023-07-03 1:35 AM
Hi @JuanjoAlm ,
BR,
J
