The effect of stress and vibration on stm32f3 microcontroller performance
hkane.1
I ran into a problem in a project, the program works normally without any problems on the lab desk, but when I take the hardware to test it in a more realistic environment, it crashes.( I am debugging, I know from there).
The working environment has a lot of vibration and a higher temperature.
Can it be due to high vibration and does mechanical stress have an effect on the performance of the microcontroller? Do you have a document or experience about this?
10 REPLIES 10
Hello @Peter BENSCH,
What vibration level can STM32 be subjected to in general? Is it a safe decision to install the STM32 LQFP64 package on a vibrating equipment as a part of Vibration Measurement device that subjects the MCU to lifetime of vibration of about 1g from 10Hz to 2000Hz?
I have been struggling to find any relevant information to make informed decisions on this regards.
On the flipside, I have seen multiple products with MCU & the MEMS Accelerometers assembled on the same PCB & installed on a vibrating equipment.
Your guidance & insights may be helpful.
