2010-12-21 9:59 AM
New STM32F105/107xx USB Host library
2011-05-17 5:19 AM
I am trying to simplify and linearize USB hot functionality for specific task. USB Host example (http://www.st.com/internet/com/SOFTWARE_RESOURCES/SW_COMPONENT/FIRMWARE/stm32f105_usb_host_lib.zip -USBH_HID_KBrd_Mouse) in IAR works perfectly with STM32F107 MCU. I traced some commands and put them step by step. Somehow I receive no data from USB device. Mine C code looks like this: uint8_t speed = HCD_GetCurrentSpeed(&USB_OTG_FS_dev); // dummy read USB_OTG_BSP_uDelay(5000); USBH_Open_Channel(&USB_OTG_FS_dev, 1, 0, 2, 0, 0x40); USB_OTG_BSP_uDelay(5000); USBH_Open_Channel(&USB_OTG_FS_dev, 0, 0, 2, 0, 0x40); USB_OTG_BSP_uDelay(5000); USBH_Get_DevDesc(&USB_OTG_FS_dev, &dev_desc, 8) ; USB_OTG_BSP_uDelay(5000); USBH_CtlSendSetup(&USB_OTG_FS_dev, buff2, 0); USB_OTG_BSP_uDelay(5000); USBH_CtlReceiveData(&USB_OTG_FS_dev, buff, 8, 1); USB_OTG_BSP_uDelay(5000); HCD_GetCurrentFrame(&USB_OTG_FS_dev); USB_OTG_BSP_uDelay(5000); HCD_GetCurrentFrame(&USB_OTG_FS_dev); USB_OTG_BSP_uDelay(5000); HCD_GetCurrentFrame(&USB_OTG_FS_dev); USB_OTG_BSP_uDelay(5000); USBH_CtlSendData(&USB_OTG_FS_dev, buff, 0, 0); USB_OTG_BSP_uDelay(5000); USBH_Get_DevDesc(&USB_OTG_FS_dev, &dev_desc, 8); I have inserted some debug information in (1)usbh_hcs.c (2)usbh_stdreq.c (3)usbh_ioreq.c (4)usb_regs.c (5)usb_core.c files. Here is debug output port from my code: -1- USBH_Alloc_Channel (00) -1- HC_GetFreeChannel -1- USBH_Alloc_Channel (80) -1- HC_GetFreeChannel -4- USB_OTG_USBH_handle_port_ISR -4- USB_OTG_USBH_handle_port_ISR -4- USB_OTG_USBH_handle_port_ISR -4- USB_OTG_USBH_handle_port_ISR -1- USBH_Open_Channel (num=1, dev.adr=0, spd=2, ep.t=0, mps=40) -1- USBH_Open_Channel (num=0, dev.adr=0, spd=2, ep.t=0, mps=40) -2- .USBH_Get_DevDesc -2- .USBH_GetDescriptor -3- CtlReq (8) 80 06 00 01 00 00 08 === 00 00 00 00 00 00 00 00 S=1 -3- CtlSendSetup[0] 80 06 00 01 00 00 08 00 -4- USB_OTG_USBH_handle_hc_ISR -4- USB_OTG_USBH_handle_hc_ISR -3- CtlReceiveData[1] 00 00 00 00 00 00 00 00 -4- USB_OTG_USBH_handle_hc_ISR -4- USB_OTG_USBH_handle_hc_ISR -4- USB_OTG_USBH_handle_hc_ISR -4- USB_OTG_USBH_handle_hc_ISR -4- USB_OTG_USBH_handle_hc_ISR -3- CtlSendData[0] -4- USB_OTG_USBH_handle_hc_ISR -4- USB_OTG_USBH_handle_hc_ISR -2- .USBH_Get_DevDesc -2- .USBH_GetDescriptor -3- CtlReq (8) 80 06 00 01 00 00 08 === 00 00 00 00 00 00 00 00 S=0 -2- .USBH_ParseDevDesc And there is debug from original example: -1- USBH_Alloc_Channel (00) -1- HC_GetFreeChannel -1- USBH_Alloc_Channel (80) -1- HC_GetFreeChannel -4- USB_OTG_USBH_handle_port_ISR -4- USB_OTG_USBH_handle_port_ISR -4- USB_OTG_USBH_handle_port_ISR -4- USB_OTG_USBH_handle_port_ISR -1- USBH_Open_Channel (num=1, dev.adr=0, spd=2, ep.t=0, mps=40) -1- USBH_Open_Channel (num=0, dev.adr=0, spd=2, ep.t=0, mps=40) -2- .USBH_Get_DevDesc -2- .USBH_GetDescriptor -3- CtlReq (8) 80 06 00 01 00 00 08 === 00 00 00 00 00 00 00 00 S=1 -3- CtlSendSetup[0] 80 06 00 01 00 00 08 00 -4- USB_OTG_USBH_handle_hc_ISR -4- USB_OTG_USBH_handle_hc_ISR -3- CtlReceiveData[1] 00 00 00 00 00 00 00 00 -4- USB_OTG_USBH_handle_hc_ISR -4- USB_OTG_USBH_handle_hc_ISR -4- USB_OTG_USBH_handle_hc_ISR -4- USB_OTG_USBH_handle_hc_ISR -4- USB_OTG_USBH_handle_hc_ISR -3- CtlSendData[0] -4- USB_OTG_USBH_handle_hc_ISR -4- USB_OTG_USBH_handle_hc_ISR -2- .USBH_Get_DevDesc -2- .USBH_GetDescriptor -3- CtlReq (8) 80 06 00 01 00 00 08 === 12 01 10 01 00 00 00 08 S=0 -2- .USBH_ParseDevDesc Hardware USB logger shows that there is no difference in USB communication. See screenshots: http://lukse.lt/failai/2011-05-27/usb_data_modif.png http://lukse.lt/failai/2011-05-27/usb_data_original.png So why I receive no data in my application? What else should I debug?We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
