Linker file in Keil
Options
2015-02-19 7:24 AM
Posted on February 19, 2015 at 16:24
Hi all,
Is there a Linker file where to define flash sections to split my flash Memory code??
Options
2015-02-19 7:46 AM
Posted on February 19, 2015 at 16:46
It's called a Scatter File in Keil parlance. A .SCT file
Go to the Options -> Linker pane, uncheck ''Use Memory Layout from Target Dialog'' The select the .SCT file, start with the one auto-generated by prior builds.
