USB microphone example with USBX
ERROR
Could you please let me know if you’re planning to provide an example of a USB Audio device based on USBX in the near future?
By the way, the ST X-CUBE-AUDIO package is based on TinyUSB that is not officially supported. I’m wondering whether it’s feasible to implement a USB microphone using USBX instead.
Regards.
FBL
Hi @ERROR
X-CUBE-AUDIO-Kit is supporting TinyUSB and USBX including usbCls :
  • usbCls_audio_play() to read speaker data from USB.
  • usbCls_audio_rec() to write microphone data to USB.
Best regards,
FBL
FBL
Hi @ERROR
Best regards,
FBL
ERROR
Hi @FBL ,
Thank you indeed for your swift and precise answer!
Regards.
