USB High-Speed Support for STM32H7S3L8 in Zephyr RTOS
laya
I am working with the STM32H7S3L8 MCU and using Zephyr RTOS for development. Currently, I see that Zephyr supports USB FS but does not seem to support USB HS for this MCU.
  • Are there plans to add this support in future Zephyr releases?
  • Any guidance or workarounds for enabling USB HS in Zephyr would be greatly appreciated.
Thank you!
FBL
Hi @laya
Have you tried running the example firmware that is officially supported on your board? If that works without issues, you can this narrow down by focusing on SW whether it is related to:
  • Clock configuration
  • Pinout settings
  • USB descriptor
  • Zephyr USB stack integration
As a next step, I recommend testing with a minimal Zephyr configuration that reduces the kernel footprint:
  • Use cooperative threading or idle threads
  • Disable unnecessary subsystems but keep kernel enabled
If still having issues, I suggest to check with Zephyr community support channels,
:speech_balloon: Discord Server for real-time community discussions
:e_mail: User mailing list (users@lists.zephyrproject.org)
Best regards,
FBL
