Kaza K
Nov 8, 2017 8:37 AM UTC
STM32L4 Standard Peripheral Libraries
Posted on November 08, 2017 at 09:37
  1. Are the Standard Peripheral Libraries available for L4 series?
  2. If not, maybe it is possible to use StdPeriph from e.g. F4? Register addresses are the same or not?
  3. Maybe there is some way to extract it from HAL lbr?
Best regards,
Kaza
#std-peripheral-lib #stm32-l4
Andrew Neil
Nov 8, 2017 9:00 AM UTC
Posted on November 08, 2017 at 10:00
ST has deprecated the old Standard Peripheral Libraries for some years now.
Googling 'STM32L4 Standard Peripheral Libraries' gives:
http://www.st.com/en/embedded-software/stm32-standard-peripheral-libraries.html?querycriteria=productId=LN1939
The later libraries tended to be called, 'DSP & ...' - so
Googling '
STM32L4 DSP and Standard Peripheral Library' gives:
https://electronics.stackexchange.com/questions/312184/where-can-i-found-stm32l4-dsp-and-standard-peripherals-library
So it looks like you're out of luck.
But why not use the HAL LL (Low-Layer) functions:
http://www.st.com/content/ccc/resource/technical/document/user_manual/63/a8/8f/e3/ca/a1/4c/84/DM00173pdf/files/DM00173pdf/jcr:content/translations/en.DM00173pdf
See:
https://community.st.com/thread/32362#comment-97413
waclawek.jan
Nov 8, 2017 10:13 AM UTC
Posted on November 08, 2017 at 10:13
Hi Andy,
Because it's superfluous.
You asked... ;)
But seriously, we don't know Kaza's motive. He might want to port older non-L4-SPL code; he might want to see a set of examples; or he might follow best practice whatever that means. LL won't help with the first two; using it for the last one is just question of personal preferences.
David SIORPAES
Nov 8, 2017 12:22 PM UTC
Posted on November 08, 2017 at 13:22
You may want to give a try to
http://www.st.com/content/st_com/en/products/development-tools/software-development-tools/stm32-software-development-tools/stm32-configurators-and-code-generators/spl2ll-converter.html
 which helps in migrating from SPL based projects to LL.
Kaza K
Kaza KAuthor
Nov 8, 2017 1:28 PM UTC
Posted on November 08, 2017 at 13:28
It looks very interesting and if it work, it will save me a lot of time. I will definitely check it. Thank you!
