MQTT connect fails to connect to IoT Hub. Generic error of 0x10005 NXD_MQTT_CONNECT_FAILURE
‎2022-03-24 9:42 AM
I am using an STM32F429 Nucleo 144 and the Ethernet interface to run an Azure Iot client.
Using STM32Cube IDE version 1.8.0
NetxDuo versios 6.1.7
Nx_SNTP_Client Sample project
I have combined this example with NetxDuo's sample_azure_iot_embedded_sdk_with_retry.c Once the IP address and SNTP server is connected (time is sync'd) I start the Azure client thread.
My code is not able to successfully connect to the iOT hub. The call to mqtt_client_secure_connect() eventually returns the generic NXD_MQTT_CONNECT_FAILURE (i.e. 0x00010005 from file nxd_mqtt_client.h). The response code is generic and does not help with further debugging. Is there some additional logging or method to debug this.
Here is a snippet from the console output
Nx_SNTP_Client application started..
STM32 IpAddress: ***.***.***.***
SNTP client connected to NTP server : < ca.pool.ntp.org >
SNTP update :
Mar 24, 2022 16:34:9.699 UTC
24-03-2022 / 16:34:09
[INFO] Azure IoT Security Module has been enabled, status=0
IoTHub Host Name: xxxxxxxx.azure-devices.net; Device ID: stm32F429xxxxx.
24-03-2022 / 16:37:41
24-03-2022 / 16:37:51
24-03-2022 / 16:37:52
[ERROR] IoTHub client connect fail: MQTT CONNECT FAIL status: 65541
Disconnected from IoTHub!: error code = 0x00010005
Failed on nx_azure_iot_hub_client_connect!
reconnecting iothub, after backoff
24-03-2022 / 16:39:54
- Labels:
AzureRTOS
STM32F4 Series
‎2022-05-05 10:59 AM
I have opened a ticket with Netxduo team on Github https://github.com/azure-rtos/netxduo/issues/86 if someone has run into a similar issue.
‎2022-03-24 10:14 AM
The function nx_secure_tls_session_start (line 3939, file nxd_mqtt_client.c) returns a value of 56. I cannot find a #define for what this value means.
‎2022-04-26 7:58 AM
hello,
so it's a TLS problem ?
did you initialize correctly the TLS part ?
see Microsoft Azure IoT example at https://github.com/azure-rtos/netxduo/blob/1eee883def078a91b8cd19159d1796e3a8862814/addons/azure_iot/samples/sample_azure_iot_embedded_sdk.c#L182
in particular, they have additional root certificates root_ca_cert_2 and root_ca_cert_3 to be added to the TLS config.
‎2022-04-26 8:06 AM
if return value 56 is decimal, then in nx_api.h there is
#define NX_NOT_CONNECTED 0x38 // 56 in decimal
‎2022-05-05 10:58 AM
@Guillaume K​ Thank you for your suggestion from the netxduo Github repo. I already found that example and adjusted my root certificates to use the latest ones.
The return code of 56 is decimal. I was hoping the connect routine would provide an error indication like Host unreachable, TLS handshake failure, etc.
