Are STM32G4 FMAC X and Y buffers cleared by HAL_FMAC_FilterStop ?
siungsuestone
Code Order :1、HAL_FMAC_FilterPreload_DMA。
2、HAL_FMAC_FilterStart。
3、HAL_FMAC_FilterStop。
4、HAL_FMAC_FilterStart。
5  HAL_FMAC_AppendFilterData
    i want ask ,does Fmac X and Y buff will clean when step3: HAL_FMAC_FilterStop function excute ?
Saket_Om
Hello @siungsuestone
At FilterStop, the internal X1 and Y FMAC buffers are not cleared.
However, their respective internal write and read pointers are reset to the X1_BASE and Y_BASE addresses.
When you restart the filter, the new data are computed using possibly outdated X & Y values (for an IIR filter).
If you want to keep the filter context and continue filtering with new data, do not stop the filter; just append a new data buffer by calling HAL_FMAC_AppendFilterData.
Otherwise, if for any reason, you must stop the filter, then restart it with the previous context by preloading the latest X & Y values.
Saket_Om
