Failed to execute MI command
  • September 24, 2024
  • 1980 views
I recently started getting the following error when trying to program my nucleo-32 L432KC board:
Error in final launch sequence:
Failed to execute MI command:
target remote localhost:61234
Error message from debugger back end:
localhost:61234: Connection timed out.
I have tried using the cube programmer to erase the flash memory, but when trying to connect with "Mode: Normal", I get an error: "Error: ST-LINK error (DEV_TARGET_HELD_UNDER_RESET)". When changing the Mode to "Hot plug", I am able to connect to my MCU, but the "Full chip erase" operation gives me the error: "Error: Mass erase operation failed.Please verify flash protection".
Does someone have an idea what could cause this? Programming the MCU worked just fine a day ago.
Best answer by DavidL_
Ok this was solved by breaking the S9 solder bridge.
DavidL_AuthorBest answer
Andrew Neil
