2026-04-08 5:12 AM - last edited on 2026-04-08 5:22 AM by Andrew Neil
Dear STMicroelectronics Community / Support Team,
I hope you are doing well.
I am currently working with the STM32N6 Discovery Kit and noticed that it uses an external Octal NOR flash device with the part number MX66UW1G45G. However, I have been unable to locate a public datasheet for this exact component.
I was able to find datasheets for similar parts such as MX66U1G45G and MX66UM1G45G, but not for the “UW” variant used on the board. This has led to some confusion regarding the exact specifications, supported features, and command set of the device.
I would appreciate your guidance on the following points:
My goal is to develop a reliable driver and potentially use the same (or equivalent) flash memory in a custom hardware design, so having clarity on this component is very important.
Thank you for your time and support. I look forward to your response.
Best regards,
Zaeem Ahmed
2026-05-13 2:04 AM
Hi @Zaeem-Ahmed and @beSTMax ,
As already noted previously, we are not the provider of that memory either contact the memory or your local distributor of that memory to get the datasheet.
Sorry we cannot help you on this request.
2026-05-20 12:55 AM
Hi @mƎALLEm ,
thanks for the heads-up.
It's understandable to contact your local distributor if you're using the parts for a product and have some leverage.
But what is a hobbyist supposed to do? The shops/distributors likely won't answer you, same as Macronix won't answer.
BR
