ST25 NFC/RFID tags and readers
Ask questions and find answers on ST25 NFC/RFID tags and readers, including connectivity implementations and antenna design.
Resolved! ST25R3916 Inductive Wake-Up
Where can I find details on inductive sensor wakeup for the ST25R3916? It's only even mentioned on pages 1 and 11 of the datasheet. My understanding is that inductive wake-up will detect tags only, whereas capacitive will detect other objects like a ...
LltWc by Senior
  • 556 Views
Resolved! M24SR64-Y Interrupt - GPO as INT configuration
Hello, everyone,I have a problem with setting the GPO of M24SR64-Y as an INTERRUPT. The micro needs to come out of Sleep condition through an Interrupt sent from smartphone via RF, I saw that you have to set the GPO with 0x4X, but I don't know how to...
Niko97 by Associate
  • 673 Views
  • 1 replies
Resolved! Unexpected interrupt after Tx enable on ST25R3916
I'm trying to figure out some unexpected behavior (that I've posted about before) after successfully implementing alternation between T2T Card Emulation and Reader/Writer such that they seem simultaneous to the end user.During device initialization, ...
LltWc by Senior
  • 1037 Views
  • 5 replies
Resolved! CR95HF and DESFire
Posted on April 21, 2014 at 05:45 Hi Everyone, I'm using the CR95HF to access the DESFire card. Everything was going fine up to RATS and PPS. However when I tried to send the GetVersion Desfire command (0x60) using the Half-duplex block transmission...
Resolved! ST25DV64KC - Fast Read Single Block
I am developing an Android app to read values from the NFC-v tag (ST25DV64KC). To revalidate my implementation, I am using the ST25 TAP app and then sending a custom command to test the commands according to the data sheet (ST25DV64KC). From an Andro...
