ST25 NFC/RFID tags and readers
Ask questions and find answers on ST25 NFC/RFID tags and readers, including connectivity implementations and antenna design.
Resolved! CR95HF.dll and NDEF data format
Posted on January 09, 2014 at 06:40What's the NFC library used in NFC M24LRxx_Application_Software in PC? is it the CR95HF.dll? I try to know more how about NDEF format data send to NFC device from PC? For example, how to send image file to NFC targ...
ruixiang by Associate
  • 950 Views
  • 1 replies
Resolved! M24LR NDEF not recognised by Windows Phone 8?
Posted on November 25, 2013 at 20:06I've tried a number of ways to get M24LR tags recognised by a Windows Phone 8 device (Lumia 920) - but to no avail.  WP8 is supposed to recognise NDEF formatted tags but doesn't.  I've tried formatting with the ST...
dab by Associate
  • 1167 Views
  • 3 replies
Resolved! CR95HF Write command
Posted on November 24, 2013 at 18:19I use the CR95HF chip for reading and writing data in the NFC forumtag Type 2 Tag (NTAG203F). I can read the data, but can not write data to Tag, although NTAG203F is writable. When I send a command to write data,...
Resolved! STSW-95HF003 Document
Posted on November 05, 2013 at 16:29Hello, I want to download the http://www.st.com/web/en/catalog/tools/FM147/SC1871/PF259363♯, the Excel sheet named STSW-95HF003. Can you fix the link, because it is broken, it gives a 404 Error. Or you can give a ...
tacsik by Associate II
  • 1254 Views
  • 3 replies
Resolved! Enabling M24LR16E-R Energy Harvester
Posted on October 18, 2013 at 11:58Hi to all,I'm using a self-made eval board based on the M24LR16E-R dual EEPROM chip. It is very simple as it consists of the EEPROM chip, filter capacitors, pull-up resistors and, obviously the antenna.RF signal is...
danilo by Associate
  • 913 Views
  • 1 replies
Resolved! M24LR-discovery RF range versus external 3V3
Posted on August 14, 2013 at 22:24Hello all, I have been trying the M24LR-discovery board.  Without applying an external 3V3 supply to the board, the operational range appears to be only about 1.5cm (less than one inch).  There is an antenna design ...
mneary by Associate
  • 1105 Views
  • 3 replies
Resolved! CR95HF error code 4
Posted on September 25, 2013 at 16:57occasionally when I send a  CR95HFDll_SendReceive command, I get error code 4 back. 5 I understand - the USB is not connected, so I simply reconnect, but 4 is a communication error. How can I recover from this in...
duncan by Associate II
  • 985 Views
