ST25 NFC/RFID tags and readers
Resolved! CR95HF peer-to-peer
Posted on January 29, 2014 at 13:23Hello!I want to use CR95HF to establish peer-to-peer communication with Android system terminal.Is it possible at all? If not - how can I send/receive data directly from smartphone/tablet using CR95HF? #cr95hf #...
Resolved! M24LR16E-R Dual EEPROM information
Posted on January 23, 2014 at 16:29Hi,I wish to know please if using this memory is there any way to access, via RF, the information that I stored via I2C. Or is the information separated, via I2C (2048 bytes) and via RF (512 blocks of 32 bits) , wi...
Resolved! CR95HF.dll and NDEF data format
Posted on January 09, 2014 at 06:40What's the NFC library used in NFC M24LRxx_Application_Software in PC? is it the CR95HF.dll? I try to know more how about NDEF format data send to NFC device from PC? For example, how to send image file to NFC targ...
ruixiang by Associate
  • 676 Views
  • 1 replies
Resolved! M24LR NDEF not recognised by Windows Phone 8?
Posted on November 25, 2013 at 20:06I've tried a number of ways to get M24LR tags recognised by a Windows Phone 8 device (Lumia 920) - but to no avail.  WP8 is supposed to recognise NDEF formatted tags but doesn't.  I've tried formatting with the ST...
dab by Associate
  • 935 Views
  • 3 replies
Resolved! CR95HF Write command
Posted on November 24, 2013 at 18:19I use the CR95HF chip for reading and writing data in the NFC forumtag Type 2 Tag (NTAG203F). I can read the data, but can not write data to Tag, although NTAG203F is writable. When I send a command to write data,...
Resolved! STSW-95HF003 Document
Posted on November 05, 2013 at 16:29Hello, I want to download the http://www.st.com/web/en/catalog/tools/FM147/SC1871/PF259363♯, the Excel sheet named STSW-95HF003. Can you fix the link, because it is broken, it gives a 404 Error. Or you can give a ...
tacsik by Associate II
  • 995 Views
  • 3 replies
