Ask questions and find answers on ST25 NFC/RFID tags and readers, including connectivity implementations and antenna design.
Hi,I want to edit the given firmware on the ST25DV Discovery-Board. For that I have downloaded the KEIL MDK µVision 5 and was able to open the given project. But it's not able to compile because the file is too big. Can I use another Linker?
Hello I would like to know if there exists a cube project to edit the demo enviroment of the ST25DV Discovery kit?
Hi everybody I am using st25r3911 in my own pcb and I still have a problem in the first step :rfalInitialize() does not return ERR_NONEin fact I see the MOSI and CLK and CS signal but there is not anything in MISO !!pin28 in st25r3911b (mcu_clk) is o...
Hello all,I just got my new toy before few days named as ST25DV04K Dynamic NFC/RFID Tag.I have downloaded the firmwares, applications and rest of the things from the https://www.st.com/en/evaluation-tools/st25dv-discovery.html#design-scroll.I have ob...
We are using M24LR64E for configuration and event logging, try to use password to protect configuration data area. In the user manual(DM00047008.pdf), in Figure 12 and Figure 13, the password address is 0900h, but in Table13, I2C byte address is 2048...
my reader is st25r3911b-discover,the tag is st25dv04k,when I write file(the bin file )to tag,the reader wrote a block (four byte)to tag every time ,how to designer reader for writing more block to tag every time.for example two block or more.than...
https://www.youtube.com/watch?v=WyNey42oIHEit's regarding the which is used in the video'
Hello!I am new to this forum and I have a reasonable doubt regarding ST25R:We need to evaluate ST25R3911 for a new development where the main goal is that mobile phones (both Android and iOS) could read it as an ISO14443-A card. We would like to conf...
