Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
Firmware of STEVAL-ISA172V2
Hi,We are planning to develop STEVAL-ISA172V2 and design customized SMPS.I am unable to find any code. Where we can find the code?what's the procedure to get firmware source or binary from the ST?
I am new to bldc motor control and recently purchased the EVAL6235Q evaluation board. Instead of buying the suggested communication board I am attempting to control by directly manipulating the input pins. Can this be done?
Specifically I am pulling the 'motor direction' pin high, setting voltage reference pins accordingly and then setting the 'enable pin' high. The motor runs but I have no control to as the speed. Can this be accomplished or can this board only work ...
L6562 : Need to understand the functionality of the PFC IC
Hello everyone,I have made the L6562 ref circuit (for 250W provided in the datasheet) on general purpose PCB.I have discussed with coilcraft members, they have said, for initial conditions the resistor divider from rectified mains input will provide ...
jayanth by Associate
  • 1176 Views
  • 1 replies
  • 1 kudos
youtu.be
Having trouble starting your motor?, watch this https://youtu.be/As6cLKZzHyA It clearly explains what the startup process is.
DGome by Associate II
  • 795 Views
  • 0 replies
stm32g431
on stm32g431 cannt used 2 current sensor isolated how can resolved this problem ?how can tel to motor control team for add this one on library ?
