STEVAL-TSP004V2 configuration changes for 24V output
I recently obtained the STEVAL-TSP004V2 eval board, and tested it with Tripp-Lite NPOE-30W-1G injector. As supplied the eval board worked fine.I then modified the eval board as I require a 24V output, so :removed T5 and fitted a Coilcraft POE300F-24L...
