Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
Resolved! SCTWA70N120G2V Ron data
I want the specific Ron data corresponding to different VGS values (e.g., 8V–15V) when the MOSFET switch SCTWA70N120G2V is in the linear region.
Kyle4 by Associate
  • 353 Views
  • 1 replies
  • 1 kudos
Output capacitor selection for LD1085D2M-R
Edited by a ST moderator: Update the title and the content with the part number Hi,I'm using LD1085D2M-R regulator. There is no certain information about output capacitor ESR limit value for stabilization.  -Input : 5V -Output : 4V @3A -Desired Outpu...
hamzdmr by Associate II
  • 716 Views
  • 5 replies
  • 4 kudos
BTA41-600BRG stuck ON in some cases
We are using BTA41-600BRG triacs on our temperature control boards to turn on 240V tank heaters. The tank heaters are 1500W, 3000W, or 4500W depending on the unit model and operate at 240VAC. The circuit we are using is attached. We use a FOD4108 dri...
t_jonas by Associate
  • 396 Views
  • 1 replies
Resolved! [STWLC38] Operating Frequency and ASK modulation cycle
Hello,I'm developing a Qi compliant product (Not getting Qi.) using STWLC38JRM.Please respond on Operating Frequency and ASK modulation cycle to get back to the testing agency.[Operating Frequency]Qi standard defines the operating frequency from 110 ...
Ryoma by Associate III
  • 673 Views
  • 3 replies
  • 2 kudos
Resolved! 555 timer _ ASIL B requirement
Hello Team   I have a general query.    Do we have any 555 timer with ASIL-B or ISO26262 compliant.    I am interested in discrete level solution rather going with MCU and my aim is to have redundant control/ feedback/LIMP HOME mode embedded in the 5...
Resolved! Marking Code on L78L15ACUTR - meaning of last 3 digits?
Hello,Our customer has inquired about the meaning of the last three-digit code in the marking on the L78L15ACUTR.For example, some parts are marked with "8L218" or "8L243" on the top surface.Could you kindly explain what "218" and "243" stands for?Th...
STI by Associate II
  • 259 Views
  • 1 replies
  • 1 kudos
Resolved! Unable to Find MOSFET
Hi, dear. Could you please help me find the datasheet for the MOSFET with part code GF329MB, as well as other compatible MOSFETs with similar specifications?   Thank you in advance for your help! Hi, dear. Could you please help me find the datasheet ...
manmohan by Associate
  • 358 Views
  • 1 replies
L9780 Supporting Firmware
Hello,Does anyone have any firmware for interfacing with the L9780 wideband controller. I am planning on using a LSU 4.9 but any sensor configuration would be useful.Any information is appreciated. Thanks,
