Others: STM32 MCUs related
Find out more about STM32 implementations with external components, discuss use cases, and discover how to use new tools and ST components.
Hello! Does anybody know why the function HAL_StatusTypeDef HAL_FLASHEx_Erase(FLASH_EraseInitTypeDef *pEraseInit, uint32_t *PageError) doesn't work properly with STM32F407, but the function works perfect with STM32F303?
Wnen I work with STM32F407 and call this function my programm goes to infinite loop cause of unexpected interrupt. But there is no problem with STM32F303.Is there any features STM32F4 I don't know about?
Fry by Associate II
  • 1340 Views
  • 3 replies
  • 1 kudos
Writing to EEPROM of STM32L051K8?
I am trying to flash a data to `EEPROM` of `STM32L051K8` with HAL library. This functions keeps returning `HAL_ERROR`. With debug i found the problem. In HAL Flash library before writing data to `EEPROM` it checks for error flags with `FLASH_WaitForL...
Truestudio was working fine. After adding 1 line in a source file, I got stuck with the attached error message. Changing the source back to original did not help, still getting the same error. Any suggestions how to proceed?
No source file named C:\\vmi\\viber_x4\\x4_fw_1_1\\BootLoader\\SRC\\bl_main.c.Program received signal SIGTRAP, Trace/breakpoint trap.GR_IconMenu (iconSTR=0x23a0008, Options=0) at ..\..\COMMON\SRC\GraphMenus.c:151151    if (xCount == 0)Halted to watch...
fbackvid by Associate II
  • 451 Views
  • 0 replies
sw4stm32/openocd can no longer edit variables
Weird one this - some time in the last few weeks I can no longer edit the contents of variables in either pop-up view or expression view after I have hit a breakpoint. Memory Browser seems to be OK. This occurs on f3 and f7 MCUs so presumably somethi...
STM32H7, Atollic strange debugger failure
Debugging on STM32H753-EVAL2 board with Atollic.Sometimes the debugger gets into weird state while target is running.Only full stop (red block) and reset buttons are active. The break button (||) is grayed.Has somebody seen this behavior?I thought it...
Pavel A. by Super User
  • 426 Views
  • 0 replies
