Others: STM32 MCUs related
Find out more about STM32 implementations with external components, discuss use cases, and discover how to use new tools and ST components.
Basic IDE setup for an STM32F100RB and IAR
Posted on October 02, 2015 at 04:36I am experiencing a surprising amount of difficulty trying to set up an STM32 VL Discovery board (STMF100RB) with an IDE (IAR EWARM). I have downloaded the STM_STD_Peripherals.zip. and can open examples from it's f...
scook116 by Associate II
  • 1768 Views
  • 6 replies
EEPROM emulation in STM32F103 (using CoIDE)
Posted on September 13, 2015 at 16:52 Hello World! I need an EEPROM memory on my device and there is no I2C pin free to use AT24Cxx. So, i should use EEPROM Emulation (as said in AN2594 http://www.st.com/web/en/catalog/tools/PF257846#). I...
tux by Associate II
  • 762 Views
  • 1 replies
mbed Serial on Nucleo UART4
Posted on August 13, 2015 at 01:14 I have already asked this question on the mbed site: https://developer.mbed.org/questions/59656/Serial-What-are-the-Supported-pins/ It isn't clear from the Handbook whether this is even suppos...
STM32-MAT Blockset CAN block bugs?
Posted on July 30, 2015 at 15:51Hello,I just started to use the CAN blocks in this block-set, I�m using Matlab 2014a and I�m expensing some potential bugs in the generated code. Am I doing something wrong or are these bugs?1: CAN_Filter block dose n...
Error due to GNU ARM toolchain usage in IAR workbench
Posted on July 30, 2015 at 09:39I recently started programming with STM32F4Discovery board and am using IAR workbench as the IDE. I am supposed to use an already developed program in Eclipse as a part of my project. When I imported this into IAR Wor...
sommer by Associate II
  • 713 Views
  • 1 replies
Nucleo-F070RB + mbed PB6 problem?
Posted on July 28, 2015 at 19:34I have a Nucleo-F070RB and am using mbed for programming. Is there something special about PB6 that prevents it from being used as a GPIO? It appears to be configured as as oscillator output (?) at 500Hz.The code belo...
jay23 by Associate II
  • 1049 Views
  • 3 replies
