Others: STM32 MCUs related
Find out more about STM32 implementations with external components, discuss use cases, and discover how to use new tools and ST components.
IAR Simulator
Posted on December 28, 2016 at 13:41Hello,I have made a code that initialize a timer of an STM32F0 to tick every 1 ms and generate an update interrupt , and i want to test if my code work correctlyMy questions:1- The IAR startup file should be Added...
Cesar cfg by Associate II
  • 1552 Views
  • 5 replies
Resolved! I cant define a class in uV5
Posted on December 25, 2016 at 02:00I set all the pins in CubeMx,added a class to a .h filerenamed main.c to main.cppincluded the .hand 'class' is undefined.is there a switch in Cube for this ? using an '091#class-undefined #uv5 #keil
T J by Lead
  • 1531 Views
  • 5 replies
ARM mbed semihosting fs with stm32
Posted on December 15, 2016 at 20:48One of the unique things about ARM mbed-enabled boards (such as my 32F746GDISCOVERY) is that they have a small storage area that is shows up in Windows or Linux when the board is connected by USB. An executable ca...
aaron2399 by Associate II
  • 1023 Views
Resolved! While using same project in SW4STM32
Posted on December 06, 2016 at 09:45 Dear Sir, As we discussed earlier, difficulties on adapting project in SW4STM32 and mdk-keil, things might related to compiler, including paths, wrong pre-processors, undefined characters, unresolved items, mi...
Is anyone using MBED?
Posted on November 30, 2016 at 01:28Does anyone know the status of mBED development route? Are people using it? I looked at a site that showed how to use it and it looked similar to Arduino code. Just looking at the options since the SPL is not goi...
STM32L152 issue erasing EEPROM
Posted on October 20, 2016 at 11:13Hi,I have the following routine for writing to EEPROM which checks whether the data to be written matches the current EEPROM contents. If there is no match, the EEPROM contents are erased and the new data is writte...
s0071904 by Associate II
  • 544 Views
  • 1 replies
