Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Incorrect example files are on the ST website for STEVAL-ISA164 STNRG388A digital controller eval board. If someone could create a simple example to fix missing Example 4 we would reward you for your time
I wasn't sure where to post this request for the STNRG digital control IC example files so I'm reposting in STM8 after getting no responses in Power Management or from technical support in a weekThere is a link to download 5 sample files for the STLU...
Hey guys, I want to controll motors via joystick. Unfortunately, when I connect joystick to my STM8S103F3 analogue pins it reads 800 in the middle position instead of 512.
As the result, the right side has very short run (it reaches 1023 in one sixth of travel). The same for Y axis, the same with another joystick. Both joysticks work properly with arduino - middle 520 (or so). Is there any (obvious) reason; how can I r...
RRozu.1 by Associate
  • 949 Views
  • 0 replies
