Other: software
Resolved! inductance equations contain an error
The square antenna inductance equations in app notes AN2972 and AN2866 seem to contain an error (or misleading terms) where it describes the average diameter parameter. The notes say the average diameter in millimeters but it needs to be in meters in...
imarike by Associate
  • 560 Views
  • 1 replies
STM32 and GPS Neo m8n
Hello, so I have a question, about my problem, thats bothering me for a while now and its about my GPS sensor Neo m8n connected with USART2.The sensor works well with my laptom connected with programmer via USB to u-center program, showing great valu...
LHaup.1 by Associate
  • 1298 Views
  • 1 replies
Why did my LoRaWAN app only sends empty data?
I'm trying to send some GNSS data using LoRaWAN, but my gateway only receives a blank string. Pretty sure the AppData.Buffer values are right since it prints the right thing on my console.As you can see my gateway didn't receive any payload.Here's my...
Wtuya.1 by Associate
  • 763 Views
  • 0 replies
SCTL90N65G2V�?�LTSPICEモデル�?�インストール�?��?��?��?�
SCT040HU65G3AG SCTL90N65G2V�?�LTSPICEモデル�?�インストール�?��?��?��?�教�?��?��??�?��?��?�。SCT040HU65G3AG�?�LTSPICE�?�AutoGenerated機能を利用�?�シミュレーション�?��??るよ�?��?��?�り�?��?��?�。SCTL90N65G2Vも�?�様�?�方法�?�インストール�?��?��?��?��?�エラー�?�発生�?��?��?�。.libファイル�?�修正�?�必�?�?...
yuki1 by Associate
  • 368 Views
  • 1 replies
Teseo-LIV3FL Low Power Mode Not Working
I'm using a Teseo-LIV3FL GNSS module for my project and trying to set the low power mode settings using Teseo-Suite software. Tried using the Low Power settings from the wizard but after get the fix it still draws around 50mA of current.Expected beha...
AFidi.1 by Associate II
  • 1108 Views
  • 7 replies
Configuration using Teseo Suite doesn't work as expected
I have a Teseo-LIV3FL GNSS Module and I want to configure the low power mode configuration using Teseo Suite software. Here's my setting I was expecting after two fix reports my Teseo will go to sleep mode in 180 seconds, but after getting bunch of f...
  • 419 Views
  • 0 replies
