STR71x_lib/71x_init.s : type error
olivier239955_stm1_st
Posted on April 01, 2005 at 05:44
3 REPLIES 3
Posted on March 24, 2005 at 08:41
There is a Typo (type error) in the 71x_init.s file where the stack range are initialized. Instead of 265 (which can cause stack misalignement) it should be 256!
Could you confirm whether the problem is fixed on the latest lib version?
hichem2
Posted on March 24, 2005 at 10:04
Hi oli32,
Yes you are right it's a mistakes in the STR71x Library, it's already corrected in the lastest lib version which will be available in the web site soon.
Thank you and best regards,
Hich ;-)
hichem2
Hi all,
The STR71x software library V2.0 is already published on the STMCU web site.
Cheers,
Hich :-P
