programming the control register (st7538)
thorsten-kopp
Posted on September 23, 2005 at 06:01
37 REPLIES 37
boicuflorin
Posted on April 28, 2005 at 08:35
Hi Reny,
Sorry for my time response :-(
Please send me your email and then I send you
my routine and we can talk about them.
By.
reinhard_larch
Posted on May 04, 2005 at 16:30
Hi flo123,
here is my e-mail address:
reinhard_larch@yahoo.com.au
thanks a lot, very much appriciated!!!
reny
boicuflorin
Posted on May 12, 2005 at 06:55
Hi Reny,
I send you an email !
By
yuanye-28
Posted on June 10, 2005 at 01:42
hi,flo123
Could you send me?
my emial is
mailto:yuanye-28@163.com
thank you very much.
boicuflorin
Posted on September 20, 2005 at 10:55
I want to implement an FEC (forward error correction) in my ST7538 modem. What algorithm you had use ??? can you give me a suggestion :-)
Thank's
krapf
Posted on September 21, 2005 at 11:13
Error Correction?
Well, I am using the old Hamming code.
The amount of hamming bits to be used is up to you to decide...
But there is a class of FEC codes called TURBO CODES that are much more efficient, but they need a lot of processing power.
Rafael Krapf
BRASIL
info79
Posted on September 23, 2005 at 05:50
Hi everybody,
I'm working with ST7538. I'm transmit between neutral fase and ground line to avoid problem in trifase system with 132,5 Khz frequency and 2400 baud. In some site I have problem of noise and the CD/PD line toggle. This problem occure some hours a day. By your esperience should I change some parameters as frequency or baud rate to improve the comunication ?
I'm use a preamble byte every transmission to syncronize the comunication but during noise doesn't work correct.
Have you suggest me a way to avoid noise by software ?
What is the best configuration of register to avoid noise and have best performance ?
Thanks to everybody help me....
info79
Hi Everybody,
another problem I have is a noise on clock CLR/T. In some device it's a stable but in other the clock swing. The hardware and components are the same. If I disconnect the transformer from line the clock became stable. Have you suggest something ?
I have best performance with transformer 2:1.
Thanks for help.
