Help!!!! ST712FR2T6 flash programming
daveevans9
Posted on December 08, 2006 at 00:04
daveevans9
Posted on August 24, 2005 at 14:03
Hi all,
Compiler-IDE: Keil uVision 3.2
Target: ST712FR2T6
Dev board: Hitex - ST710F
JTAG debugger: Keil ULINK
I am having a great deal of difficulty programming a ST712FR2T6, we 'appear' to be able access using JTAG without any connection problems, however when trying to erase or program, an error says:
Flash timeout, reset target and try again.
If we attempt to run from ram, we get a verification error along the lines of offset X value x expected y.
I have scoped the lines of the JTAG and all appear very much alike our dev board which works ok.
any ideas?
DaveE
elcommselva
Hello DaveE,
Try to reset[once or twice] your circuit from the RAM mode. Then erase your target[once or twice] in the RAM mode and then try to progarm it in the FLASH mode. I think this may help you out.
Cheers,
Selva
