Flash Programming
k_arthur
Posted on June 13, 2008 at 14:28
Flash Programming
10 REPLIES 10
lillian_200601
Posted on May 17, 2011 at 09:42
I use the Keil compiler and MCBSTR9 EVAL board to run the FMI example and find it is not working unless you compile the code in thumb mode instead of ARM mode. Can anyone give me a clue what difference between thumb and ARm mode? Why the FMI example can only work in Thumb mode? Highly appreciate any info.
