Compiler error
giovanni239955
Posted on May 28, 2003 at 14:22
Compiler error
3 REPLIES 3
giovanni239955
Posted on May 17, 2011 at 11:34
Excuse me, my compiler generates this error:
Unable to find a register to spill
(insn:HI 81 80 83 (parallel[
(set (reg
F 291)
(reg
F 16 R0))
(clobber (scratch:SI))
] ) 54
abnormal program termination
gcc9.exe: Internal compiler error: program cc1 got fatal signal 22
gmake: *** [adc.o] Error 1
but I can't find a description of the error. Where may I find it?
Anybody can help me qhere to investigate?
Many thanks
romain2399
Please attach your adc.c file.
giovanni239955
Hi Romain, the problem I think is in this statement:
'' else if ( (((unsigned int) NTC_TEMP_mis) < ((unsigned int) (PNTC_TEMP_mis + DELTA_TEMP_mis))) ||
(((unsigned int) PNTC_TEMP_mis) < ((unsigned int) ( NTC_TEMP_mis + DELTA_TEMP_mis))) ) ''
In fact, if I write (for test):
'' else if (TRUE) '' all works.
I will try to simplify it.
Only to make clear my situation, I'm porting an ST7 application (compiled with Cosmic) to an ST9.
Many thanks
